Cptsideways
My AC compressor early r12 version had sized up taking out the clutch rubber safety bit too. I happened to have a few lying around from other Toyotas.....
Toyota Soarer 1990-1993 JZ engine ones ones are identical (R12 fittings) just the top adaptor is swapped over along with the front pulley as its LC is V belt & Soarer is multi. Electrical connectors need swapping over otherwise its the same unit.
Now its time for a regas & looking forward to chilled drinks in the fridge
