alarms
Looks like my Sparkrite immobiliser relay is failing - the second one. Do
you know if its a common problem ?
(Yes, I know, you all have factory fitted alarms, but you might have these
on your other cars).
Jon
'92 HZJ80 ex UN surplus in Bosnia
Jon
My alarm played up about a year ago (went off all on its own). Although it says "Toyota" on the outside I'm told it is the same gubbins as the Sparkrite unit.
Turned out to have 2" of water in the horn unit in the engine compartment - apparently a common problem with the UK units that have been shoddily installed. Has been fine since I emptied it out and sealed it. Worth a check?
Christopher Bell
Devon
1996 1HD-FT
Christopher
Where is the steam fair?
Dave Harris
[Email address removed]
97 VX 1HDFT Devon UK
----- Original Message -----
To: <[Email address removed]>
Sent: Sunday, June 06, 2004 9:51 AM
Subject: Re: [ELCO] alarms
: Jon
: My alarm played up about a year ago (went off all on its own). Although
Sparkrite unit.
: Turned out to have 2" of water in the horn unit in the engine
Worth a check?
: Christopher Bell
: Devon
: 1996 1HD-FT
: > Looks like my Sparkrite immobiliser relay is failing - the second one.
Do
: > you know if its a common problem ?
: > (Yes, I know, you all have factory fitted alarms, but you might have
these
: > on your other cars).
: European Land Cruiser Owners Mailing List
: Further Info: http://www.landcruisers.info/lists/
Dave Harris wrote:
Combsland Cross, about 4 miles east of South Molton. Signposted off the A361 north devon link road at the B3227 turn
Goes on to about 5-ish today.
Not that many steam things - about 5x traction engines, lots of vintage tractors (some younger than me ... vintage???)
Some impressive models in a tent, gun-dogs, vintage cars, good bouncy castle complex, a few stalls...
... and no winches.
Christopher
Quoting toy80 <[Email address removed]>:
Jon,
I don't know about Sparkrite but my second Cobra (Italian) is on it's last
legs after a few months of use (the first didn't work out of the box). And I
won't ask them again for replacement under warranty.
Rgds,
Roman
London UK
'92 HDJ80
Not completely on topic but related ... I accidentally blew the fuse to
the fuel shut off solenoid on the injector pump a while back but didn't
realise that was what I'd done. Came to use the car, no go. Called AA,
and left him to sort it (was in a hurry). He poked and prodded and said
solenoid was faulty so I gave go ahead to order one. Later I fitted the
new solenoid and of course it still didn't work so I checked the power
to it and guess what? No power. Anyway, I eventually tracked it down to
a blown fuse because a poorly placed screw had pierced some wiring ...
Strikes me pulling that fuse would be a pretty good way of disabling the
car in future. Might not be Thatcham approved but it gets my approval.
Jon.
93 & 94 HDJ80
Stourbridge,
West Midlands,
UK.
-----Original Message-----
On Behalf Of roman
Sent: 07 June 2004 11:57
To: [Email address removed]
Do
these
Jon,
last
And I
Rgds,
Roman
London UK
'92 HDJ80
Haha ... the F26 (7,5A) fuse can be a pain, just as not being able to start
the engine and blaming the immobiliser while the automatic is left in gear :-)
Actually, if you leave the HI-LOW stick in neutral most lowlifes will never
figure out why the car won't drive.
Immobilisers can be a real pain if you don't know what they do and how to
disable them. Having limied trust in modern electronics, particularly Italian,
I have created a bypass using hidden switches so that the engine can be
started even if the alarm/immo fails completely.
Rgds,
Roman
London UK
'92 HDJ80
Jon Wildsmith said:
I used to do that when parking in London, down 'ere in the cuntry we don't
even bother locking:-)
Mobile: 07971 540362
80less at the moment - Roll on June!
