Simon5030
- Jul 15, 2014
Just a heads up really,
Been trying to find a kit to overhaul my alternator (bearings really grumbling) and in the end just has to pass on this one due to leck of information on the Denso unit, so i thought i would opt for a refurb unit.
Straight forward job looking at the manual, drained the coolant, viscous fan and shroud out and away we go, would have been a good design if that shroud would have come out without the fan but you cannot win them all.
New alternator in and back together, fired it up and charging light came on after 5 mins!!!
Checked the running voltage and it was about 14.6 (within specs), everything was working other than the light.
So checked the circuit and it requires one side of the LED to come up to 12v to turn the light off, straight forward i thought, so i checked the correct (grey) alternator wire and both running and off it was to ground!
Assumed faulty new alternator or regulator, swapped it out for another and guess what, same again! so they have now sent me a Lucas one and it worked straight away and the voltage is about 14v when charging.
Below are the labels, RTX one is supposed to be correct but doesnt work, hope this helps someone avoiding the same problem, have also learned that if you are careful you can avoid draining the coolant and just leave the expansion bottle supported on the RHS with a strap
Simon
Simon
