MisterCruiser
- May 28, 2014
As in pic, recently replaced my turbo, the oil leaked into the intercooler when the turbo failed, I drained the oil out of the intercooler just by gravity, left it to sit etc,,
However, I am getting oil dropping onto the ground as have my undertrays off and it's coming from that hose pictured. I haven't used this cruiser much since replacing the turbo as was doing a lot of other rust fabrication work on it and I'm thinking it might just need to be driven to burn off the oil in the intercooler, could that make sense?
Or should I remove the intercooler again and see if I can drain more oil out of it?
Or is there another issue that I don't know about that could be causing the oil to leak here?
