- Jul 24, 2015
Morning all,
As the title says - my ARB twin air compressor has stopped working. I used it to inflate all 4 tyres from deep sand pressure to tar pressure like I have many times over the last few months without a problem. Drove to campsite, went to use the air gun and the compressor wouldn't turn on. I checked the 40 amp fuse and it had blown.
Replaced fuse - still won't turn on.
I noted that if I turn on the headlights the air compressor and ARB diff locker switches don't illuminate - so this leads me to the wiring loom.
Getting out the old multimeter I can see that there is 12v getting to the compressor via the power loom. And there is 12v leaving the compressor into the switching loom connector, although I note that there is kind of a funny set-up where there are 3 wires into the connector on the compressor side, and 2 out on the switch side, with the 12v being in the wire that doesn't have an opposite wire....if that makes sense??? Anyway its how ARB designed it so I assume that isn't the problem.
Anyway I can't find any power at all in the switches. I don't remember their being a fuse in the switching loom, and looking at the wiring diagram from ARB there isn't a fuse shown.
Just wondered if anyone has had a similar problem? Or any ideas on what to check next?
Thanks in advance.
Nick
Thanks in advance.
Nick
