On my 100 I picked up the speed sensor pulse at the engine ECU but it's the speed sensor on the rear output housing of the transfer box on 80's and 100's (pretty sure 120's are different but Gary knows the details for that). For an 80 you should search the net for how to install an electronic speedo corrector as that taps into the same signal but you should be able to find it behind the dash somewhere at one of the ECU's. Mine is already corrected by a different gadget I built. It's possible I'll build a corrected output into this and remove the existing correction device but it's not a high priority for me.
There are other things the trip meters do BTW. For the A & B trips it calculates average speed, might be useful for anywhere with average speed fines For the P & L trips it maintains totals as well as the current trip values and calculates l/100km or mpg from the totals.
