Guys
Its a constant battle avoiding the AT oil Temp light coming on while
climbing the dirt roads of Ethiopian highlands.
They are the worst roads I've had the pleasure of so far.
Have tried everything -
Drive as hard as I can - mainting higher speed to increase airflow and
assist radiator cooling. This has had the best results so far but when
it does overheat the coolant is boiling - I mean aggressively bubbling
boiling. I assume the additional heat is generated from racing the
engine. This requires at least a half hour cool down period and the
high temp leads to increased chance of Temp light coming on on the
next incline.
Have also tried driving slowly ( below 1800RPM ) - this dosent work
either but when the light comes on its only a five/ten minute cool
down period and no agressive boiling of coolant.
Its the same whether I'm fully loaded or running light load of fuel
and provisions.
Of course the big variables are rate of climb, outside air temp and
road surface - all impact the frequency of cool down stops.
On the plus side my diary is in good shape after ethiopis
Is there anything else that can be done I wonder??? Any suggestions or
experiences appreciated.
AT oil (OEM) and filter was changed 10K km ago. Coolant is topped up and OK
If I was doing this trip again there is no way I'd have AT
transmission and I would advise anyone intending to go off road in
Africa to stay well away from AT transmission. Not only do they
overheat, are not suitable for sand or big altitue variances, but
there is no knowledge base here for service or repair if they did go
wrong. Opposite being the case for manuals.
My AT transmission is ceretainly the worst piece of kit so far.
My ARB rear diff is a close second but will save that for another day
Niall
PS - the Hilton in Addis Abba rocks!! They have real food.
next incline.
and provisions.
Niall
