wobbly
Am going to do a simple oil service on the 95 with my lad.
Am going to do oil, oil filter, and fuel filter.
Couple of questions -
Oil - have loads of semi synth 10W40 - will this be ok?
Fuel filter - is it an easy swap?
I've read that the thermostat is a pain to change as its at the lower end of the rad/block - I would normally change this as standard, is it really that much of a pig to get at?
Am intending to get a new water pump and timing belt fitted - is this a difficult job on this engine? If so I will get my garage mech to do it.
Pete
Pete
