- May 13, 2014
Since getting back from our trek I noticed that the car wasn't bursting into life in the same way. Even less so if left more than a day or two.
So, I first checked the batteries. The indicator on the DS one was showing black instead of green, so as a temporary measure I changed that over for one from my disco. This seemed to cure the problem but nonetheless I started to monitor battery voltages following a run and then the following morning.
Each time after a run there was about 13v - same in both batteries. The following morning I checked and there was 12.8v in both. After disconnecting the DS from the PS battery, I checked for a drain and found none on the PS battery and 0.17a on the red wire of the grey connector block next to the fusible links on the DS. I haven't checked this further (yet). So, I took it out for a run again to top them up. Then before leaving it overnight, I disconnected bothe batteries from the car. Each had 13v.
Next morning, I measured again and found the DS battery had 13v, but the PS had 11.8v. So, it seems, when the two are connected, the PS battery was pulling charge from the DS one hence both measuring less but the same as earlier. So, I temporarily replaced the PS battery with the other from my disco.
I'm hoping my logic/knowledge is right here.....can someone who is a master of the dark art of electrickery confirm?
As there wasn't a problem with a drain before the battery problems I'm assuming a 0.17a drain is nothing to worry about.
