If a sealed lead acid pops it may spray acid everywhere depending where it fails. Just placing a heavy load on them can be the trigger causing a build up of gas greater than the valving can handle which is what makes them go pop. Stick it in a battery box to protect from that and it should be safe.Justin_Elliott said:But how do 'sealed lead acid' compare to 'gel' batteries from a performance and safety aspect...![]()
