battery charge light and fuel water sediment light
moggy1968
so, both these came on today!!
I have drained off the water from the sedimenter. While I was there I had a good fumble round in the dark ('cos I couldn't find my torch!) and found a rubber cap like thing on the top floating around which I presumed should be attached to the top of the sedimenter so I have refitted that as best I can blind. Is this not being attached likely to have caused the sedimenter to fill with water? Drove 200 miles yesterday in heavy rain.
Do I now need to prime the fuel system?
Also, at the same time (first start up this morning) the battery charge light came on. The dash voltmeter is reading a good output (above halfway) and the belts are tight. any ideas?
cheers
drained the sedimenter off quite abit, but the light is still on.
recharged the batteries, then ran the engine with all ancills on, voltmeter still reads good, but battery light still on
any ideas?
