Olazz
- Apr 23, 2010
Guys, I have had a problem with the batteries on the truck slowly running down over a period of weeks and couldn't figure out why, as I have done nothing new and this seems to be more of problem over the last few months.
I finally decided to learn how to check if there is a battery drain. I'm a complete when it come to electrickery, so after a few attempts I finally got what I think were the right readings on the 20ma scale of the voltmeter.
The reading with ignition off and all doors closed started at 2.8ma , and kept on creeping up the scale to 7.12ma. The longer I held the probes to the battery the higher the number climbed.
I eventually traced the drain to the Magcharger torch I have hard wired into the truck (been there for 2 years now) and on removing the fuse, the readings fell to 0.9ma, but then again the readings kept on creeping up to settle around 3.2ma. This is where the numbers stay, even if I remove all of the fuses in the cab and under bonnet.
if I then open the door the number jumps to 6+ma
The only other thing I can think of is a pirañha alarm fitted with a red LED flasher in the cab.
Is this normal?
Shouldn't the numbers be under 1
Anyone able to advise?
Is this normal?
