negotiating that nowGav Peter said:Very chic JonHave you tried it out yet??
negotiating that nowJon Wildsmith said:[quote="Gav Peter":1fl7xjey]Very chic JonHave you tried it out yet??
24Seven said:negotiating that nowJon Wildsmith said:[quote="Gav Peter":184h90k3]Very chic JonHave you tried it out yet??
Gav Peter said:20 years eh... You'd get less for murder!!!Congrats to you & the present Mrs Wildsmith dude
Got it from BOAB which is where my last one came from as well, they are the UK importers. Like every sleeping solution it seems, it's not perfect but having been on the ground, then in the previous RT, then back on the ground again I'm sure what I want now I thinkBat21 said:Where did you get it from Jon, was it a UK supplier?
Thanks for all the congratssilvercruiser said:Happy Anniversary and looking good, i like the idea of the hard shells as they seem to me to be a bit more resistant when green laning![]()
er, how expensiveJon Wildsmith said:lol I'd forgotten about that but maybe there is a connection after all seeing they're so expensive![]()
Thanks Jon, I had already given some thought to thatJon Wildsmith said:With your back though Chas you might want to stick with a wind up model or at least try closing an air top before you buy because the front might be a bit tricky for you.![]()
Before I went to get mine from BOAB TJ had done a pretty good job of convincing me it would be a struggle to close so I'd been giving it some thought and concluded that I'd either climb up on the bonet or open the sun roof and pull it down through there! The issue is that whereas at the back you can stand in the middle and pull straight down, at the front you're off to one side reaching over quite a way making it much harder to pull straight down.Cossack said:Thanks Jon, I had already given some thought to that, I thought maybe a cleat fixed to the front of the top that I could hook something onto while standing on the ground
. Before I do get one I shall go up to BOAB's and investigate further.
