Bleeding the brake system
It will soon be time for changing brake fluid on the grey eminence. I recall doing that some years ago using the "semi automatic bleeding system" thats fitted to the 100. I dont quite recall exactly how the procedure was :oops: .....can anyone help on this -and maybe some other 100 owners will "discover" a new feature on their car ;)
Saludos
Lars
I guess that's referring to that you don't have to pump the pedal. Just hold it down and it will flow until the reservoir is empty.
There is a high pressure pump which does the job for you, and an accumulator.
Also remember to check the fluid level when the pressure is let out of the accumulator, i.e. after turning the ign off and depressing the pedal 30 times.
