Blue Print NEW rear discs early 80 series
karl webster
Guru
I have a pair of brand new in the box Blue print rear discs.
Price £70 for the pair
Early 80 series
I can bring to lincomb if needed :thumbup:
Karl will they fit mine it's a 92
Also need electric aerial switch and a hand brake cover
Ha, ha! I'd like them but I'd need the axle to go with them mines a '95 with drum brakes on the rear! :lol:
Sold.
Can you get cheap courrier over to you Clive?
Short answer is No!
Unless you're offering Karl! :lol: My eternal problem, if I was there I'd empty your yard! :oops: Dammit!
On a more serious note Karl, I presume there's no conversion from drum to disc on the 80? I guess it's an axle swap or nothing, correct?
If I'm honest Clive I have never ever seen drum on an 80. I imagine that it would be fairly simple. I expect you would unbolt the end of the axels and swap them over. Maybe half shafts would need swapping.
Maybe someone else could shed some light on it.
On a more serious note Clive. I would love you to empty my yard. I could retire :lol:
I could take some photos of my axle ends if that may help. The key issue would be whether the caliper mounts are on a "bolt on" flange or directly mounted onto provisions on the axle casing itself.
I can deal with spannering, welding is not so easy for my limited skill/equipment resources!
AFRICA spec 80 were drum on the back at least 2 people I know are drum braked rear down there.
