Glad to see u fixed it. Not fun having little to no brakes
Lal
-----Original Message-----
From: [Email address removed] [mailto:[Email address removed]]On
Behalf Of Peter Browning
Sent: Friday, May 13, 2005 7:17 AM
To: [Email address removed]
Subject: Re: [ELCO] Brake problem - MBC? UPDATE
Bled the system again last night, but this time by the old fashioned
method so I could see what was happening.
Got some air out of rear n/s and fron n/s calipers but thankfully no more
black gunge - the fluid is running clear as a bell.
Hey presto the brakes are now better than they ever were!
Almost
chucked myself through the windscreen the first time I had to brake this
morning!
So that's another job jobbed.
Pete
Julian Voelcker wrote:
Peter,
I would be inclined to go for a full bleed and fluid change - it is
amazing how much crap gets shunted around the brake system when you put
new pads in.
Don't forget to bleed the proportioning valve on the rear axle - call
me if you want to be talked through it.
Mobile: 07971 540362
-- European Land Cruiser Owners Mailing List Further Info:
http://www.landcruisers.info/lists/
