warrenpfo
- Jul 21, 2010
I had not noticed it prior to fitting new rear discs but when taking a left hand corner there is a noise that comes from the right hand rear (outside) wheel which sounds a lot like a pad rubbing on a disc. I plan on rebuilding the right hand rear brake calliper this weekend if I get the chance as the left was sticking and so bout a full kit to replace the rubbers etc.
I can only think that under the stress of taking the corner something has enough movement in it to create the rubbing noise. It is possible that the rear disk is “loose” enough for it to then touch the pads under the sideways force of taking a corner or would you put money on the fact is has something to do with the calliper?
I cant seem to work it out but just thought I would ask.
