Slepetau
- Jun 26, 2020
My car have just went through an EU control at my local brand workshop, where it was found that both front break shields was loose due to corrosion/wear.
So I have to replace or remove in order for my car's EU-control to be approved. Since I often drive many hours in slushy snow, I figure it's best to replace.
Recommendation from brand workshop
As my car have passed 220kkm (137 k.miles) the brand workshop recommend also replacing the wheel bearings (since they have to disassemble that as well). Do you think it is reasonable to take the extra cost of replacing the wheel bearing at this mileage ?
Third party suppliers of brake shields
Also - the brake shields that the brand workshop offer, has a material cost of between 7-12 times of spare parts that is manufactured by 3. parts. This leads to two questions:
Is there any risk using third party suppliers for break shield - i.e. does the break shields keep any weight on other parts ?
In the web shops, I find brake shields from several manufacturers. The question is if one or more of these brands has reputation for less than desired quality of parts (no particular order):
Some additional info
Manufactured year: 2009
Full Tectyl treatment of undercarriage two years ago.
I'm not skilled in car repair and neither have the means of lifting the car for inspection.
Thanks for answers in advance.
- Blic
- Van Wezel
- Abakus
- Herth+Buss Jakoparts
- Klokkerholm
