- Mar 7, 2010
I have an annoying problem with the ABS (I think) 'pulsing' the brake pedal.
This happens probably 80% of the time when slowing to almost a complete stop, or actually stopping, at low speed & under gentle braking ie approaching roundabouts, traffic lights etc .
The wheels are definately nowhere near locking up.
The pedal only 'pulses' for a second or so & the car stops ok.
Braking hard does not seem to cause the problem or make it any worse.
Its been like it for a while now & is an annoyance, has anybody any ideas on what could be causing this, somebody did suggest the rear load sensing valve, but not sure which way to adjust it as I havnt got pressure guages etc as suggested on Lcool, could this be the problem or something more deep rooted. I have cleaned up the wheel sensors when doing bearings etc but no different
There is quite a bit of weight on the back with rear bumper & twin wheel carrier, LR fuel tank etc
Its a 94 12 valve 80
Thanks
Thanks
