(brakes) (bearing greese)
Hi Guys
I have the cruiser booked in for the suspension for next tuesday, this was
the earliest he could do When the cruiser is there I have asked him to raise
the diff breathers, gear box and transfere breathers. I have also asked him
to bleed the brake system aswell. see I do take note of all the excellent
advice you lot give me. I have a question about the brake fluid, does it
matter what type is used and will it use 1 or more litres to flush.
What is the name of the greese for the bearings. I will do as Julian
suggests, is it the lithium stuff that I need and does it make any
difference what brand. Im asking this because I can get the greese and brake
fluid for him rather than him use a cheapo , but if it makes no difference
then i will leave it to him.
Thanks john
92HDJ 80 1HDT Ireland
Hi John,
You must have a Lithium based grease for the wheel bearings and a Moly based
one for the Birfield.
Most motor factors in the UK seems to sell either multi-purpose grease that
(should in theory) do both or a general purpose wheel bearing grease and
general purpose CV joint grease.
Personally I would prefer something a little bit better than boggy basic
grease so hunted around and have found a couple of good ranges of grease from
Mobil.
Are you going to get him to check the Birfield?
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
Hi Julian
O I dont know weather I should just in case its bad news.
John C
----- Original Message -----
To: <[Email address removed]>
Sent: Monday, July 18, 2005 3:57 PM
Subject: Re: [ELCO] (brakes) (bearing greese)
Hi John,
What do the balls look like on the axle with regards the grease?
Hi Julian
The balls are nice and shiny only a little grease on both, so this is good
YES. Anyway I will have him look at it if he has the time that is.
John C
Sent: Monday, July 18, 2005 5:07 PM
