Brakes feedback - 100 series pads in an 80.
Hi Ian,
Don't you have the squealer tabs in the pads - when they get down to
about 4mm they should start sqealing to warn you to change them.
Mobile: 07971 540362
Hi Ian,
Not sure, they didn't squeal that's for certain, just a quiet scraping
noise. Maybe it's my hearing - the other half noticed it first. To begin
with I thought it was just some muck in there but when it continued for
a few miles realised I had a problem.
I plan on checking the fronts soon so will have a look. How do I
recognise squealer tabs?
Ian.
Julian Voelcker wrote:
>Hi Ian,
>>I had the fronts go
>>down to the metal whilst up in the Peak District on holiday.
>Regards,
>Julian Voelcker
>European Land Cruiser Owners Mailing List
>Further Info: http://www.landcruisers.info/lists/
Hi Ian,
There is a small strip of metal riveted to the back plate of the pad on
one end that folds back over to the pad side and protrudes 3-4mm -the
strip is only 5-6mm wide.
Hi Ian,
Julian,
I didn't have them on the rear pads I just fitted but I just checked my
spare fronts and they have them. The rears were the same make - both
from Milner. I didn't look at the old front ones that scored the disks
as a garage fixed them for me. But they certainly didn't squeal. I'm now
going to carry spares just in case - don't fancy paying ?300 again for
something that should be the price of a round of beers!
Ian.
>Hi Ian,
>Regards,
>Julian Voelcker
The pads I used recently were from EBC, no fade and they seem to be
wearing well. You do have to be carefull with Milner stuff.
On Thu, 10 Mar 2005 14:52:29 +0000, Ian Packer <[Email address removed]> wrote:
to
that
se
of
mm
Not sure Milner are to blame the pads that didn't squeal were fitted in
Japan!
Should the Toyota rears have squeal tabs then?
Ian.
>> Julian,
>>spare fronts and they have them. The rears were the same make - both from
>>Milner. I didn't look at the old front ones that scored the disks as a
>>garage fixed them for me. But they certainly didn't squeal. I'm now going to
>>carry spares just in case - don't fancy paying ?300 again for something that
>> Ian.
>> Hi Ian,
>> I plan on checking the fronts soon so will have a look. How do I recognise
>>squealer tabs? There is a small strip of metal riveted to the back plate of
>>the pad on one end that folds back over to the pad side and protrudes 3-4mm
>>-the strip is only 5-6mm wide. -- Regards, Julian Voelcker Mobile: 07971
>>540362 Cirencester, United Kingdom 1994 HDJ80, 2.5" OME Lift, ARB --
>>European Land Cruiser Owners Mailing List Further Info:
