Cage
Ronanjordan
Hello all,
I going to make a cage( 20x20 steel meat in a frame)
to go between front seats
And rear loadspace of my lwb commercial 90.
I want to b able to remove it so will bolt
It to roof handle points, but I want an option
To be able to move the cage back to divide ip the rear
Loadspace also.
Any ideas for lower mounts? Would probably
Need 2 sets of brackets for it....
All ideas welcome!
What are you going to keep in there, your pet tiger :o :lol:
I did that with LB and used the grab rails as you suggest but also the bottom seat mounting points. These are the ones halfway up the footwell so to speak. I shall see if I can did out my pics and ping them to you for ideas. I didn't mesh mine, as I don't own a tiger of course.
Well have you not heard....
The Celtic tiger has popped, gone kaputt!
I was cutting trees today and filled the back
With lengths to take home and thought it would b
A great time to have the cage fitted in case
It all flew forward. Might break the windscreen!!!
Will use the grab handles which will b quite easy
Just sorting the floor mounts as it has a flat floor/load space
Which I don't want to bastardise so much
Well I started this morning and have a frame made
That hangs off grab handles behind the seats,
Brackets bolted to the floor so must make another
Small frame to tie the brackets to the upper frame,
Then wire mesh both with 20x20 mesh.
Got pix on my iPhone so will try get them up
i used grab handles and forward tie-down loop bolt holes for my system
You have a tidy job done in fairness to you.
My top frame is just a rectangle. Didnt follow the
Profile of the inside trim, may put edges out off it, see how it goes.....
Next plan will be storage.
