Red Cruiser
- Dec 30, 2018
Last year fitted the item (or similar)below, found it beneficial. Cost $40 or $50 from memory ( which may be completely wrong) had to buy the necessary tubes and mounting bracket to install it.
Every since I purchased our HJ61 had a smidgen of oil near the Turbo Al/Rubber Tubes now none. But probably the main reason after 300,000 Km of ownership is I want to reduce/eliminate any smoke coming out of the exhaust and I believe this unit does that as well as I collect around 2 or 3 table spoons of oil from the unit every 2000 or 3000Km.
https://www.repco.com.au/en/brands/ryco/ryco-crankcase-filter-assembly-catch-can/p/A5390852
Peter
Peter
