As per the wanted section my Center Difflock is not working, I have changed the part I throught it was and it does not work!!
So any other ideas as to what it cold be?
Paul
Paul
Jon Wildsmith said:Does the ABS normaly go off when you press the switch to lock it or when it locks?
Jon Wildsmith said:I think there are EWD's in the FSM's so you should be able to test all the bits.
Jon Wildsmith said:If you short the locked switch connector on the transfer case you would still be able to use the axle lockers![]()
