- Mar 7, 2010
Two weeks ago when I started the car I heard a sound of a flickering relay. Sounded like behind the RHS kick panel. Tried to remember what was behind there, and started switching things off and on to see if something would stop the relay from flickering. Turned out it was the centre diff.lock relay, and when activating the lock-button, the relay was stable. But the diff lock light did not come on. Drove like this for a week, until I had some time on my hands. Measured a bit and found that the actuator motor was open, i.e. no connection between the two outer pins of the plug to the actuator itself. Since I had a spare one in the garage, I changed the actuator, and all seemed to be ok. Diff.lock worked and the relay was stable. Opened up the old motor and found a burnt rotor.
At the time of installing, I was trying to figure out how to be certain to put the actuator in in the right position. The handbook doesn't help much, it says: "Hint: At the time of reassembly, set the motor actuator in differential lock condition". I thought that couldn't be right as the diff was not locked, so I put it in in the unlocked position - same as the broken one was.
Now, after a week, the relay started flickering again !!!!! wtf. d@xx. My suspicion now is that the actuator can't quite move into it's fully unlocked position because it is mechanically stopped by the gear to the diff.lock, and that this was the problem all the way. As the contacts for the actuator motor are in the actuator itself, it has no idea about the status inside the transfer/differential unit. I'm thinking that this is was also the cause of the original motor to burn.
Is this theory sound - is this my problem? And: is there a foolproof way of positioning the actuator correctly upon installation?
I'm thinking of just moving the gear one tooth towards locked, or rather just move the contacts 2-3 mm past the end of the contact path for unlocking, and try again.
As it seems like most peeps on this forum have 80-series - I think the diff.locks are exactly the same.
