Indeed and I have wired all my batteries end to end with substantial cabling and hydraulic crimp lugs. Over engineered perhaps but it does mean that you always have 'alternatives' when in a tight spot.
I had a long conversation with a battery supplier about Optimas. He knew all the discussions about them and said that simply the biggest issue was too low charging voltage. They must get 14.5 regulalry if not all of the time. My CTEK does that for the rear one, but the front one only gets the standard alternator cycle and you know what, it shows. So when it's parked up over the week, it's always hooked up to a CTEK 10 amp charger on AGM cycle. Now it seems much happier. The back one is at 100% when I park it up and still at that when I collect it. The front battery runs some very small items like the clock whilst parked so is always drained albeit very slowly. Now it gets the constant feed, it doesn't drop off nearly as fast when parked without the charger. They like being charged hard and fast. My rear Optima gives staggering performance. We'll see how it does on the Morocco trip running fridge and the front one running the freezer. There is one more reason why I like them. They fit perfectly in the only space I had!
