Wandering Aengus
- Oct 14, 2012
This is a slightly long tale so please bear with me!
About a week ago I noticed that my fridge, whose battery is charged through a charge controller that comes on at 13.1v input wasn't working due to the battery being flat.
I immediately checked the charging voltage of my alternator (A1) at the batteries in the engine bay and noticed it was only 13.4 - 13.5v. The fridge started charging again but only at 13.5v, it usually charges at up to 14.4v (endangering my supply of cold beer - mission critical). Otherwise the car was running fine.
Luckily when I bought my car it came with a spare second hand alternator of unknown history ("A2') This had a different plug on the rear but I found one to match it fairly easily and swapped it in, charging voltage was between 14.2v and 14.4v, all good.
The next day my 10A dash fuse blew, the first fuse i've had go in the 2 years i've owned the car, swapped it out, no problem.
The day after that the bolt that tensions the alternator and the belts sheared so, guessing the problem was the voltage regulator on A1 I removed the regulator on A2, put it on the body of A1 - it was charging at 14.2v, all good.
The following day my dash fuse blew twice in about 30 minutes and as I was running out of 10A fuses I swapped in A2 body now with A1 regulator just to get me back to town. To my surprise for the first hour of driving this combo ALSO charged at 14.2v, suggesting to me that the A1 regulator wasn't the problem after all. After an hour the charge dropped down to about 12v.
When I got to town I fitted a new non toyota regulator AND a supposedly working toyota regulator of the same shape but different part number, both gave charges of about 13.5v.
Any help would be greatly appreciated. I'm going to try and find a regulator that matches at least the first bit of the parts number on the ones I have but to be honest it's pretty unlikely i'll find one here in the bush in Gabon.
- Various bush mechanics here in Congo & Gabon have tested both alternator bodies and rectifiers using a lamp and have declared them fine
- I have checked and cleaned the main ground on the engine block
- Batteries are less than a year old and I have no reason to suspect they're bad, when the car is switched off they're sitting at about 12.5v charge, a bit low presumably due to not being charged fully?
- Both my regulators have slightly different part numbers, both have a big 'M1S' and then '12600-' but that is followed by different numbers on both
- It may be conincidence but I think that all the times the dash fuse blew i'd just switch on the CDL, this could just have been either that I only looked at my dash after pressing the button to check it had engaged and just noticed the dash wasn't working then. I presume that the dash fuse has something to do with my problem?
