Check your vehicle’s MOT status and history online
I regret checking mine, it just confirmed that the previous 5 owners did not give a damn about maintenance...
Thanks Matt, in 4 years my 80 had only these comments... and they were this year:-
Reason(s) for refusal to issue Certificate
Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Advisory Notice issued
Rear seats removed at time of test
I have this also, there is a code for this advisory which puts to bed any concerns about any MOT place not carrying out an MOT because of missing seats :thumbup:
Glad I got the seller to renew the MOT when I bought it. Reasons for failure...... :shock: :shock: :shock:
Nearside Front position lamp(s) not working (1.1.A.2b)
Offside Front position lamp(s) not working (1.1.A.2b)
Offside dip beam Headlamp not in good working order adversely affecting beam image (1.2.4a)
Offside main beam Headlamp aim too low and too far to the right. (1.8)
Windscreen washer provides insufficient washer liquid (8.2.3)
Both Windscreen wiper does not clear the windscreen effectively (8.2.2)
Nearside Front wheel bearing has excessive play (2.5.A.3c)
Offside Front wheel bearing has excessive play (2.5.A.3c)
Offside Rear Brake disc(s) excessively scored (3.5.1h)
Steering column shaft Steering system fouling (2.2.D.2a)
Offside Rear Brake pipe excessively corroded (3.6.B.2c)
Nearside Inner Front Brake pad(s) less than 1.5 mm thick (3.5.1f)
Front to rear Brake pipe inadequately clipped (3.6.B.1)
Offside Front Brake pipe excessively corroded (3.6.B.2c)
Offside Front Brake hose excessively deteriorated (3.6.B.4d) **DANGEROUS**
Nearside Rear Brake pipe inadequately clipped (3.6.B.1)
Rear tail pipe Exhaust has a part missing (7.1.1a)
Front flange Exhaust has a major leak of exhaust gases (7.1.2a)
Rear Exhaust has part of the system excessively deteriorated (7.1.1a)
Handbrake cable Brake pivot has restricted free movement (3.5.1j)
Offside Rear Anti-roll bar linkage inadequately repaired (2.4.G.1)
OSF brake hose split Brake performance not tested (3.7)
Service brake efficiency below requirements (3.7.A.9)
Parking brake efficiency below requirements (3.7.A.10)
Jees Lorin
Sounds like it was nearly rebuilt. Guess you have peace of mind for some time to come.
Mine shows play in the front wheel bearings every year except this year.
He put that on to cover his ass for not testing the rear seat belts. The inertei.... inersha.... inertia.... :doh: bits that bolt to the side pillars :D were still there but obviously nothing to clip them into.
I just checked Fiery's MOT history & she's never had a single fail or advisory :dance: :dance: :dance:
Last MOT was @ 147500 miles & she's now done 161000 miles :P
Cheers for that you've made my day :D
I must sort out my hand brake before the 16th of next month then :think:
Only 2 advisory notices on the same year for low front tyres and no fails. Well happy :thumbup:
