Thanks Clive
So how does that work? Is the 12 v taken by using two batteries in parallel
and then switched to series to start?and then back again once started? The
12 v electrics being isolated during the start sequence?
We have a system like this on the British Aerospace Jetstream 31/32 series
aircraft, except is a 28/56 volt system. The batteries flick over to series
as the starter speed spools up the turbine at I think 10% rpm and then back
to parallel at 60% when the starters dis-engage and the engine becomes self
sustaining. The system voltage never actually reaches the true parallel
voltage due to the current being drawn by the starter.
Is this what happens in the Cruisers? Or is the second 12v battery solely
used for starting? Or does it parallel up with the primary battery once the
start sequence has finished?
Date: Sat, 12 Jul 2008 13:13:00 +0100
Subject: Re: [ELCO] LWB Coils sprung Land Cruiser system voltage?
Reply-To: [Email address removed]
------=3D_Part_27678_30914042.1215864780550
Content-Type: text/plain; charset=3DISO-8859-1
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
Neil,
They are 12volts with a 24volt starting system, or the 80 diesels are
anyway.
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Subject: [ELCO] LWB Coils sprung Land Cruiser system voltage?
Date: Sat, 12 Jul 2008 11:46:59 +0100
I have an old 1982 HJ60 cruiser that is all 24volt, including bulbs, trailer
wiring, the lot.
These modern LWB cruisers, are they 12v? or 24volt? My mate has a 10 year
old SWB that has twin batteries, but all bulbs etc are 12v. Have not looked
at it closely enough to see how it is wired up.
Is it all now 12v, or a split 12/24v system? Or what
Neil
Neil,
anyway.
Clive Marks
wiring, the lot.
Neil
