Great Outdoors
- Jun 24, 2014
Hi all,
Just looking for some advice : I drive a 1998 3.0L Prado 95 (it's a 5 door), basically the coolant in the rad. is just plain tap water which I have to drain out and replace with correct coolant/anti freeze. There is no bung/tap on the rad. to drain the system so it seems that I'll have to take the lower hose off the rad.
To do this do I have to strip off the engine ''sump protection plate'' or is there an easier way to drain the system. Just wondering is there a plug on the engine block somewhere that's easily accessible ? There's no owners manual with the vehicle and this is my first Cruiser so I'm on a learning curve, I find this Forum very helpful and informative.
Also can I ask how often should the oil in the transmissions & gearbox be changed and what's the recommended oils.
Thanks all.
Thanks all.
