CV Joint Replacement
Guys
This is an extract from a previous posting from Julian
"When replacing the cv joint (also cheaper from Milners) you should also replace the end plate that transfers the drive from the CV to the hub"
Does anyone know what this part is or if that's a part of the "Front Hub and Swivel Seal Kit" supplied by Milners?
Niall
Hey Niall
If memory serves me right its called the drive flange and its not part of the kit but Milners do them, and yes its a very good idea to replace it while your at it. I will wait to see if im right.
john 92HDJ 80 1HDT
John
RE : If memory serves me right its called the drive flange
Thanks for that!
NIall
PS still haven't done anything on that oil....
