I've ordered me some bits & bobs from Damar Webbing & they delivered while I was away
Selection of 5 ton 50mm recovery strops
1 x 2000mm in
Black to be used as a bridle between my two front pig tail hooks.
1 x 4000mm in
Red for general recovery & towing on the queens highways.
1 x 6000mm in
Red for general recovery.
1 x 8000mm in
2 x Bespoke (very short strap on ratchet & reversed hook) 800Kg ratchet straps in
Red for securing the coffin box in the rear of
Fiery.
1 X endless 800Kg ratchet strap in
Red to replace my existing worn one.
4 x 3000mm 800Kg cam buckle straps in
Red.
(one to secure my Zarges box another to stop the coffin box flying forwards in an accident & the other two just to replace my existing yellow ones).
2 x 1000mm 800Kg cam buckle straps in
Red.
(both to be cut & secured to the sides of the coffin box for securing the lid in place)
Do you see a common theam here
I know it's a bit shallow isn't it
I do already have the 4, 6 & 8 meter 5 ton recovery strops in
Blue as they matched the colours of my last truck
But
Red will look better inside
Fiery
I also have more than enough cam buckle straps but they are not
Red either
Anyways
Very happy with the service & products from Damar
Top chaps
http://www.slingsandstraps.co.uk/
