DIN sockets now headlamp upgrades
Ed wrote...
The Australian spec 80s have separate main and dip headlight, don't know
what they would cost but you could mess about with bulbs to your hearts
contect with them.
SNIP
Beg to differ, as the owner of an Australasian market 80. (As are
many in my neck of the woods).
There are not separate lamps for dip and main at least for those up
until late 1996.
There are four separate rectangular lamps. The outer two have
main/dip filaments. The inner two have main beams only. (Some will
remember the difficulty that I had preventing the snow building-up in
them which I cured with an Oz made Aunger headlamp protector screen).
The lamps are of very high quality, and originally sealed beam, I
still have 2 of them working well, but have replaced 2 with bulb
holder style lamps.
One 'feature' of this set up (a lot of 'features' with Toyotas) is
that when on dip beam, there is a trace of current running through
the inner lamp's filament which just glows deep orange. This has been
observed in all the 80's I see with this type of lamp, which includes
the many we have had in office fleets.
As for upgrading the power of the lamp themselves, I tend to agree
with another choice (Roman?) which is to go the driving lamp route.
The 80 main beam is great but the dip notoriously feeble. It is the
same with my Pajero, yet also using the mandatory Jap market foglamps
the dip beam is well augmented using them without any offence to
other road users.
When I grow up and have enough pocket money saved I will put a couple
of driving lamps on my bullbar and leave the headlamp circuit well
alone. That way I can install a simple relay system with a dedicated
power supply and will not upset any of the Toy electricals. JB - I
would do it that way if you can mount the lamps in the front.
Back to JB's DIN sockets. I also used a splitter for larger cooler
box (4x2 litre water bottles ++) GPS, radar scanner, walkie talkie.
etc. etc. But the coolbox 6 amp draw was plenty on its own, so I put
in a separate socket to run that which I tapped into the main feed
off the ignition switch. I did it this way primarily not to make
another excuse for a leak through the bulkhead when I am fording.
Now get those DIN sockets fitted JB ;o)
Jon
'92 HZJ80 ex UN surplus from Bosnia
I use PIAA driving lamps and bloody good they are too!
Foglamps with dipped beam!!!! That's illegal, in the UK at least.
Pete
Jon C-W wrote:
Hi Peter,
Are they - I thought all front facing fog lamps were geared to run on
dipped beam on the basis that you can't see a bloody thing with high
beam on in fog!
Mobile: 07971 540362
1994 HDJ80, 2.5" OME Lift
Hi Peter,
beam on in fog!
It's illegal to use front or rear foglamps unless vision is severely
impaired by either fog or falling snow. Not rain, or drizzle, or crap
dipped beams, it's illegal to use them unless in fog or snow!! :-)
They are usually wired to run with either dipped beam or sidelamps only,
but not main beam. But they are still illegal to use!
Pete
Julian Voelcker wrote:
>Hi Peter,
>beam on in fog!
>Regards,
>Julian Voelcker
>European Land Cruiser Owners Mailing List
>Further Info: http://www.landcruisers.info/lists/
Peter wrote...
SNIP
Oh, well slap my wrists, got it wrong again. Good thing that the
driving lamps I am going to put on the 80 will be used in countries
where its a nice gesture when a vehicle has a light at all ! One
advantage of living outside 'civilised' europe.
I will now go and join my old mate JB under his stone - till next time.
Jon
On 11/16/05, Peter Browning <[Email address removed]> wrote:
He, he.... if that was the case, half of all UK motorists should have
their bank account set up for tickets paid by direct debit :-)
Rgds,
Roman (London, UK)
'92 HDJ80
DIN sockets now headlamp upgrades and stones
Hey Jon -c-w
Ouch can you please move a little to the left. and dont park you vehicle in
the veg patch, dont you think its about time at your age you thought about
having a stone of your own.
SNIP
Jon
