MisterCruiser
- May 28, 2014
I'm researching my options with regards to my faulty / noisy rear diff which has up/down play at the pinion shaft.
Deciding whether to get it rebuilt, buy a 2nd hand or buy a new aftermarket one.
I'm leaning towards a 2nd hand unit.
Anyway, if going 2nd hand, are all 120 series rear diffs the same? Are they all LSD type? My Haynes manuals seems to say all 120's have LSD rears! Mine has no electronic actuator physically attached and obviously no rear diff lock switch in the cabin.
So, am I correct to assume mine should be the LSD type.
However, if I do the test below in the Roughtrax 4X4 link below, "guide to to tell if you have a LSD or not", my rears wheels when both jacked up spin in opposite directions? Note: I'm doing this test with the transfer box lever in the normal "H" road position.
Am I correct in saying this only proves that my rear diff could have a broken LSD allowing the wheels to spin in opposite directions as if there is no LSD, but that the rear diff is actually an LSD type, just broken?
roughtrax4x4.com
I have to remove the rear diff as it's faulty anyway, when I have it removed is there any way to tell if it's an LSD by looking at it once removed? Does it have physical parts that I could see that a non LSD wouldn't have?
How can I tell if I have a rear Limited Slip Differential (LSD)? | RoughTrax 4x4
A. Unfortunately on many models the data given by Toyota does not always confirm what type of differential is fitted, more often it just states “with” or “without” LSD which isn’t that...
