Rob
I have been trying to locate a drain on my batteries for some time without success. Could someone please confirm what is the best way to find the drain and what equipment to use. I have an 80 with 24v starting system and a leisure battery connected in parallel to the main battery. The leisure battery does not go flat only the main ones so the split charger is doing its job. So the test the current drain on the batteries I disconnect the positive terminal on all 3 batteries and I use my Maplin Unit-T multimeter to measure the current draw on the main battery on the positive terminal. Now this is were it gets tricky as either my multimeter is crap or the drain constantly varies. On the 0-20A setting I get below 0.5 apms after it has settled but on the 0-200mA scale I usually get around 50mA but I have blow the fuse on that setting twice as the current draw is high initially and then it reduces. I removed all the fuses and added them back one by one but I could not find the current drain due to varying results from the multimeter. Do I need a better multimeter, or current clamp or is my method flawed?
