Dual beam spot lights
Hi,
Do any of you know a source of dual beam spotlights, giving high and
low beam?
Been trying with google but can't find anything sensible.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Julian
|low beam?
Anything that takes an H4 bulb (sometimes referred to as P43T) will
provide both main and dipped beams.
You can get standalone headlights from "classic" suppliers, for example
http://www.norbsa02.freeuk.com/goffylighting.htm (scroll down to the 7"
H4 unit). But they may be a bit retro for your taste!
Another alternative would be to buy a cheap 7" set of driving lights and
to replace the light bit with a standard 7" H4 headlight reflector unit,
but you would have to do something creative round the back to waterproof
the back of the bulb, as most cheap driving lights are shallower than
the typical H4 unit.
I also came across this
http://www.amazon.com/Optilux-Hella-H71010321-Model-Driving/dp/B0002MA3O
O which is not main/dip, but rather "driving + fog" in one package.
Hope this helps
Christopher Bell
Many thanks Chris, didn't occur to me to look for lights supporting H4
bulbs.
I'll pass the links on to the 'customer' ;-)
Julian.
IPF in Australia makes a very potent (and expensive) dual beam spotlight.
See more at http://www.arb.com.au/ipf_lights_australia_international.php
They require an additional stay mounted on top of the light, as well as the
IPF wiring harness for these lights. They are well worth it.
Allan
South Africa
FJ79 4500EFI double cab conversion, ARB, OME.
----- Original Message -----
To: <[Email address removed]>
Sent: Tuesday, January 09, 2007 1:30 PM
Subject: [ELCO] Dual beam spot lights
Hi Allan,
Thanks, I thought they might do, but as you say are very expensive and I'm
not sure if the owner would be willing to pay that much.
I did see some Rally style ones (not IPF) ?345 GBP, but they did look good
On 9/1/07 11:30, "Julian Voelcker" wrote:
PIAA make stunning stuff, but expensive. You'll find them in the UK at most
good motorsport outlets.
Neill Watson
