Electical plug for sub tank switch.
hopeless wanderer
Hi, does anyone have a part number or an actual plug for the sub tank switch by any chance ?
Just need to get the dual tank install over the line or it'll end up like my lights which after 5 years still aren't wired in.
According to a search on Toyo the switch part number is 84560-60030 That's for a 96 Australian 24 valve. There were dash changes along the way so there is always the question as to whether you pick the right style but it's a staring point. Then over to Google Images ...
Cheers Chris.. How about the plug at the back is that a generic toyota plug ? I've done away with the rear heater hopefully that plug is the same.
Sorry, I think I wired mine in manually with pins and solder. It was a long time ago. Don't think I had any harness. I used to to fire a relay.
