- Jul 24, 2015
So a weird thing happened yesterday. We went through some quite deep water - not stupidly deep, but deeper than we would normally go through. Continued driving. Stopped to play in the creek (we're touring around the US at the moment). Drove. Stopped. Drove to the campsite. Stopped. Went to start the car to shuffle it over and couldn't get it to start. Starter was trying to turn over the engine, and the battery was fine, but it wouldn't fire up.
I also noticed that the gauges weren't working. Dash lights were working.
Pulled a few fuses - everything fine.
Turned the key again to see what was working in case it was the ignition, and noticed the gauges spring to life. Turned it over and it started fine.
Same thing happened this morning.
Its a Diesel engine, so the only thing I can think is a short near the fuel pump, although that doesn't explain the gauges....
Any other thoughts anyone? We are about to drive down to Argentina over the next 18 months, so I could do with figuring out what the problem while we are still in the US if possible.
Any thoughts much appreciated. TIA
N
N
