Empty axle 61
LandelSur
spain
Hello everybody,
Could someone tell me if the 61´s front empty axle (case) is the same for the one that has the block and the one that hasnt?
Thank you
Hello everybody,
Thank you
I'm not sure I understand the question, could you be more specific? I have a 61 and cant see any difference to a 60 one.
Hello AndycrusierguyLomas,
The 61 can have differential lock or not have it.
My question is the following one: if the front axle housing of 61, i.e., the empty axle, is the same for the one with the lock as for the one with no lock.
I know that it is diferent for the 80 one. I do not know the 61's front-end housing. I have a 61´s front axle with lock, but I have to change the casing and I only get the casing of a 61 without locks. My question is whether they are the same or is there any difference.
Ah, lock.
That is something I cant help you with as I don't have one with factory lockers ( I think from memory they are cable operated) but I think I know a guy with a 61 with them and I will ask him tomorrow as he also has a 60 without to compare.
Leave it with me.
