MisterCruiser
- May 28, 2014
As in the title, Im having trouble with my 1997 Colorado 1kz-Te engine. It has been getting harder to start the last while with longer cranking needed, but now when it does start it dies after about 4mins when the engine starts to shudder and then cuts out itself with white/grey smoke out the exhaust. Is this a fuel starvation issue?
Its recently got a new fuel filter and air filter, but the issue was there before this service. Had no problem starting it immediately after fitting the new filter.
The injection pump has been weeping a few months, I suspect the pump is the cause, but is there anything I can check or should check before I go and remove the pump to be reconditioned.
Thanks
Thanks
