I'm about to get my hands on a 120 diesel. My old 90 took an age to warm up in cold weather, even with the warm up button (which looks the same on the 120) and I did always think about fitting some sort of engine pre heater that i could plug into the mains on a timer.
Wearing woolly gloves while driving is just so uncivilised
They must really help fuel economy and long term engine life as well, giving the engine warm oil to work with from the off.
Two sorts of mains powered pre heater are available - first is a 2kw coolant heater with integral pump that you plumb into your cooling system, second type is a heat pad that sticks to the sump and warms the oil up. And yes, you unplug before driving off. Unless you have a reaaaalllly long extension lead.
Does anyone have experiences good/bad of either?
Ta! Andy
Ta! Andy
