chadr
I thought that I would post this here, rather than in the tech section as it non-LC related, though still Toyota related!!
Our Yaris (2001 mk1 1.3 petrol) spends its life doing short journeys and runs its battery down every now and again. We have had the car for over 12 years and I have replaced the battery 3-4 times. The current one seems to be on the way out now too - failed to start yesterday and had to use my "power-pack" to start it. I've already recharged it several times over the past couple of years using a charger.
I'm thinking about replacing the battery this time with higher capacity one and was after some advice. I appreciate that the size (to fit in the smallish battery tray) will be a limiting factor and the terminal position will be another.
Other than those 2 factors, is there anything else I need to take into consideration for the usage profile?
Thanks in advance.
P.S. I have thought about a solar trickle charger, however the faff of disconnecting and connecting it up every time you use the car makes it impractical. I like the ones that plug into the cigar lighter but the Yaris one only works on the ignition. Is there a way that you can wire one in (relatively easily)? I suppose you would still need to disconnect when you start the engine/alternator starts?
Thanks in advance.
