Fluid leak?
RichC4
I have a possible coolant leak from something, but I'm not really sure what. I have oily residue on this which I assume is the atf sump. I would think it's atf, but it looks and smells like oil.
Fluid levels are normal, oil is full, atf is full (but not overfull).
Not really sure what it might be at this point. It's not much as the drive is clean, just a few drops from time to time.
If it’s oil possibly from rocker cover leak near bulkhead all the way down back of engine to the atf sump…
Not sure if there is coolant pipes around that area?
Could be that, there's a fair amount of oil around. How much of a pain to fix?
Rocker cover gasket is not hard. But yours is with intercooler so an extra step.
But with any fluid leak, always start with cleaning the existing stains and trace the source of the leak first, rather than aiming or guessing at which seal or gasket to replace.
