Fluid recommendation for a 1978 FJ40 with 2F engine
cmcmill01
Folks,
Anyone have a list of fluids they use for the above FJ40 based in the UK. including the below:
  • Engine oil
  • Transmission
  • Axle
  • Brake
  • Radiator
Plus a recommendation for a battery would be useful.
Folks,
  • Engine oil
  • Transmission
  • Axle
  • Brake
  • Radiator
From the FSM: Transmission, transfer case, axles (diffs) SAE 90W GL5. GL4 if GL% not available is OK. Gary
Over here in Oz you just go to an auto accessories outlet they put the vehicle in the computer, it gives you a list of all the oils. You select what grade to suit the climate and what brand depending on how much you want to spend it makes things easier.
