And disconnect other battery I assume as it will pull power ?
Because I seemed ridiculous to me that simple courtesy lights could drain a battery that much I pulled the radio and suspect my plugging in a previous owners amplifier leads to my radio leads might have caused the drain , I didn't reconnect the light yesterday .
Have the battery on fast charge now which i don't like doing but when its reading over 12v it can trickle all night . On my travels tomorrow so I owe you a pint if I've at least stopped the drain .
Well whichever way i do it + or - multimeter shows 0000 and thats with roof lights switched to door , 3 door lights working correctly and one unplugged from the harness
I can live with that until i can get someone who doesn't feel ill just looking at car electrics to remove all the junk wiring i inherited .
I will give the fob a go when i can start the truck but it no longer seems important .
That doesn't sound right. Even with the courtesy lights disconnected you should get some reading from the clock, alarm, radio memory etc..
If you've used the 10A setting on the meter, did you move the pos lead to the 10A position?
