Julian T
The world's gone mad....
JMHO
I see I am not alone in thinking that.
Digitally enforced break down - its a cash generator .
That it is, all thanks to EU legislation and requirements.
JMHO
Lynn just read about the EU granting Germany's manufacturers special dispensation to be able to emit twice the allowed emissions
With the engine off, pull off the sensor plug to the air mass sensor, start the engine, hold at around 2000 rpm, check engine light (orange) on (separate from systems management fault light RED). Switch off, plug sensor back in. ECU regen block is now cleared, restart, clear OBD code and THEN run the regen cycle.
If you are mechanically sympathetic, get ear plugs, if you like clean washing then take it off the line.
regards
Dave
Thanks Dave, I'll get them sorted.
I forgot to check the glowplugs - Is that just a case of disconnecting each of them and measuring tip to ground resistance? They should all be close together in values?
