Front Diff studs?
Kanooe
australia
I have snapped the studs that hold the 3rd member to the front axle housing. I’m trying to see if anyone knows where I can find new studs, nuts, and washers for my 80series??
The first image is what the stud looks like with a nut on it and the second is the studs in the housing. It snapped off after I installed the new front diff and over tightened the nut onto the studs. Very thankful if someone knows where to get new studs.
Have you tried Toyota themselves or Roughtrax?
Personally I would be concerned that the others might be weakened if you have over tightened them too but they have not snapped yet. Are you able to get hold of a torque wrench?
Yeah I wanna try replace all of them but not sure where I can find that specific stud. I did use a torque wrench but I think I followed the wrong torque spec online somewhere. I’ll have a look at roughtrax though. Thankyou very much
Feel free to check my working out
Thankyou, had a look for the 41110A Toyota part, didn’t seem to get anything. When I searched up the 9011608233 I found the rear stud, not sure if they’re the same or not but I’ll check to see. Thanks for the help, appreciate it.
I checked, but the rear diff stud is larger than the front. So still no luck there, thanks anyway though.
