Greetings all.....
Vehicle vibrating badly under load. Tracked problem to UJ's on Front Drive Shaft.
Going to remove the shaft and get a specialist drive shaft service guys to replace the UJ's. Plan being to drive on rear shaft in the interim.
Is there anything else that I should be weary of when removing the front shaft - any seals or anything that should be changed also? I have visions of unbolting the shaft & the diff oil spewing out all over the place......
Any advice appreciated.
Thanks
Niall
HDJ 81 - '95 - 300k KM
Thanks
Niall
