OK so before we start, yes there's fuel in it and yes the alternator is charging.
I jumped in on Friday to go to the AO show and the voltmeter didn't lift. Oh well, I have another meter in the set up so I could see all was well. I thought I was doing rather well on fuel getting there but today on the way home after nearly 200 miles the gauge was still reading completely full. I do not believe it's a stuck float in the tank. I'd say it failed at the same time as the volt meter but because the tank was brimmed, it looked normal. All fuses checked and every other gauge and panel light works on the binacle.
Now I did have the dash out recently to replace a lamp but there isn't one single plug for these two items that I might have left off. Plus I'm sure it was working after the replacement. I've looked at the wiring spaghetti maps but can't see any unique correlation between the two instruments. Anyone got any clues? Again, I feel this is a gauge issue rather than any failure in the vehicle.
Any thoughts chaps?
Any thoughts chaps?
