As in the title really, where on No.3 injector my truck (1HZ) has developed a fuel leak on No.3 injector.
It appears to be quite straightforward, where fuel is weeping out between the threads of the 14mm hexagonal fuel pipe retainer nut (don't know what else to call it).
I've checked it with an open-ended 14mm spanner, but it is tight. My mechanic days are over really and I seem to have lost that essential "feel" for things mechanical.
I was just wondering if anyone had had similar problems, because for the engine to run sweetly for 360k kms and then suddenly develop a simple leak like this, I suspect that the injector feed pipe may have cracked inside the retaining nut, as opposed to it being a simple loose nut, which it appears not to be.
OK, the nut can feel tight, but it may not be clamping the pipe sufficiently. You will all be saying just undo it and clean it up and replace, and it may well be that simple.
Just asking in case there's anything more sinister that I should look for, or other likely causes.
Circled (for example) is the offending nut (but mine is on No.3). The guy in this picture is already fixing mine it seems...
